How to True Bicycle wheels
Выберете то, что вам нужно
    1. How to True Bicycle wheels, How to True Bicycle wheels: шаг 1, изображение 1 из 2 How to True Bicycle wheels, How to True Bicycle wheels: шаг 1, изображение 2 из 2
      • Fit the wheel into the wheel truing stand. It doesn't matter which way the wheel is facing.
      • The wheel should be snug and securely fixed to the stand.
      • Tighten the quick-release nut and lever, making sure that there is no room for the wheel to wiggle in the truing stand.
      Спросите у FixBot
      Добавить комментарий
    2. How to True Bicycle wheels: шаг 2, изображение 1 из 2 How to True Bicycle wheels: шаг 2, изображение 2 из 2
      • Bring the calipers up until the teeth are are about half an inch from the metal rim of the wheel.
      • Start the wheel spinning slowly.
      • Slowly tighten the calipers until they contact the wheel on one side or the other.
      Спросите у FixBot
    3. How to True Bicycle wheels: шаг 3, изображение 1 из 2 How to True Bicycle wheels: шаг 3, изображение 2 из 2
      • Loosen the spoke nipples that attach to the same side of the wheel that the caliper is touching. At the same time, tighten the spokes that attach to the opposite side of the hub.
      • As a starting point, turn all the spokes half of a turn for each of the spokes near the caliper contact point.
      • In the photo, the red marked spokes are being tightened, and the blue marked spokes are being loosened. This will shift the rim closer to the viewer.
      • Spin the wheel. Tighten the calipers again until they touch the rim on only one side at a time at certain point. Repeat steps 2-3 until the caiplers touch both sides of the rim evenly at every point on the rim.
      Спросите у FixBot
Заключение
The wheel should spin without wobbling from side to side or wavering up and down
3 человек успешно провели ремонт по этому руководству.
Brett Hartt
Участник с: 04/12/10
132 308 Репутация
Автор 144 руководств
Команда
iFixit Участник iFixit
Staff
123 членов
Автор 70 512 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 16
За последние 30 дней: 68
За всё время: 6,348
