How to fix Mobee Magic Mouse disconnection issues
Выберете то, что вам нужно
Видеоинструкции
Финишная прямая
31 человек успешно провели ремонт по этому руководству.
Peter Barnett
Участник с: 09/04/16
771 Репутация
1 руководство автора
Команда
Dragon Upstream Consulting Limited Участник Dragon Upstream Consulting Limited
Business
1 член
Автор 6 руководств
5 Комментарии к руководству
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Ответить Поделиться
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Ответить Поделиться
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Ответить Поделиться
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Ответить Поделиться
What is the screw type and size for the Magic Mouse battery pack? They're so small I can barely see them! Are they tiny Allen/Hex heads?
Jeffrey Powell - Ответить Поделиться
Добавить комментарий
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 20
За последние 30 дней: 105
За всё время: 41,705
