How to test an Ethernet Cable
Выберете то, что вам нужно
  1. How to test an Ethernet Cable, Ports: шаг 1, изображение 1 из 2 How to test an Ethernet Cable, Ports: шаг 1, изображение 2 из 2
    • The tester has two ports on each part:
    • RJ11 (6P2C)
    • RJ45 (8P8C)
    Спросите у FixBot
    Добавить комментарий
  2. How to test an Ethernet Cable, Connect the cable: шаг 2, изображение 1 из 1
    • Connect one end of the cable on one half of the tester each.
    • If you are testing jacks you can just connect them with a known good patch cable.
    • If the other side of your cable is already connected to a switch or some other device you can connect the MASTER device only.
    • Only do this with cable testers you trust, since crappy cable testers might not limit the current they send through the data lines.
    Спросите у FixBot
  3. How to test an Ethernet Cable, Switch on the tester: шаг 3, изображение 1 из 1
    • Switch on the tester.
    • The tester has two modes: ON and S. There is no difference in the two modes besides the testing interval on S being more drawn out.
    Спросите у FixBot
  4. How to test an Ethernet Cable, Test the cable: шаг 4, изображение 1 из 1
    • The tester will go through all the wires in sequence. If the sequence of the green lights blinking does not line up you might have swapped some wires when wiring the connector.
    • If some lights do not light up there might be a break in the cable or you made a mistake when crimping the connector.
    • For Fast Ethernet (100 Mbit/s) you only need pins 1, 2, 3 and 6. Some cheap cables may not even have more than these four wires.
    • G means ground. For most consumer applications up to 1GbE it should be fine if your ground is not properly connected.
    Спросите у FixBot
Заключение
Good luck on your next project!
Еще один человек закончил это руководство.
Sebastian
Участник с: 08/19/18
33 352 Репутация
Автор 72 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 60
За последние 30 дней: 417
За всё время: 21,986
