Введение
If your screen becomes cracked or is inoperable, the front display panel will need to be replaced. This process involves removing nearly every component of the phone before gaining access to the front display panel.
Выберете то, что вам нужно
Insert the SIM Card Eject Tool into the SIM card tray hole.
Press the eject tool into the hole until the tray clicks open.
Insert a plastic opening tool into the Micro USB charging port with the the angled side of the tool facing the screen.
Pry the screen off the back of the phone by pushing down on the opening tool.
Slide the opening tool or spudger along the bottom of the phone and around the edge.
Once three sides of the screen are detached, pry the phone apart using two hands.
Remove the four connectors by placing the spudger between the motherboard and the connectors.
Press upwards against the connectors until they disconnect.
Remove the battery by first prying a spudger between the battery and the screen.
Slice through the adhesive by pushing card around and underneath the battery.
Инструмент, используемый на этом этапе:Plastic Cards$2.99
Using the plastic card, remove the battery by lifting it from the casing.
Remove the last two connectors from the motherboard using a spudger or your fingers.
Remove the five 2mm Phillips #00 screws using a screwdriver.
Remove the two 2mm #5 Torx screws using a screwdriver.
Pry the speaker and microphone assembly off of the phone by sliding a spudger down along the bottom.
Инструмент, используемый на этом этапе:Tweezers$4.99
Pull the volume buttons off using tweezers or the end of a spudger.
12 человек успешно провели ремонт по этому руководству.
