Введение
Use this guide to replace the back cover of your Huawei Mate 10 Pro.
If your battery is swollen, do not heat your phone. Swollen batteries can be very dangerous, so wear eye protection and exercise due caution, or take it to a professional if you're not sure how to proceed.
Выберете то, что вам нужно
Insert a SIM opening tool in the hole on the left side and push it in.
Remove the SIM card tray.
Switch off your phone.
Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
Erm… Simply impossible to open the phone this way…
I used the iOpener for 2 mins as instructed, I’ve used even an hair drier for 30 secs on max power (could barely touch the phone after) and still with the suction tool I was not able to open the phone.
It simply doesn’t budge!!!
This was much easier than I expected! ;-)
I put the phone on a hot-water bottle for about 5 minutes. I put the first pick in the side of the phone, not the top as shown in the next section. Then I kept the phone on the hot water bottle through all the following steps so that the battery glue was nice and warm when it came to that section.
Инструмент, используемый на этом этапе:Halberd Spudger$2.99
Lift up the back cover with a suction cup until you can insert the flat end of a halberd spudger.
Use the halberd spudger to cut the adhesive beneath the back cover on all sides of the phone.
Faire attention à ne pas enfoncer trop le cutter/spatule hallebarde. Surtout à l’approche des boutons ON/OFF et volume, la nappe ne passe pas loin et se branche à coté de l’empreinte digitale.
Bilan, j’ai coupé cette nappe et n’ai plus de bouton volume et on/off.
Plus qu’à chercher la piece de rechange pendant que le telephone est ouvert ;)
I found it easiest to insert the first pick on the side of the phone, not the top as shown in the pictures. The side is slightly more flexible than the ends because it is longer.
Flip the back cover over to the side.
Remove the Phillips #00 screw which holds down the metal shield, sitting on top of the connection of the fingerprint sensor cable.
When re-assembling, you can test the phone before putting the covers back on. If you test it before you connect the fingerprint reader then you need to re-start the phone before the fingerprint reader will work.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use a pair tweezers to remove the metal shield covering the connector of the fingerprint sensor.
Disconnect the fingerprint sensor cable with a spudger.
12 человек успешно провели ремонт по этому руководству.
3Комментарии к руководству
Where can I buy the back part of the phone. Email me at brownpridebandit@gmail.com
Thanks for good work you do
