Введение
Use this guide to replace the battery in your Huawei P10 smartphone.
Выберете то, что вам нужно
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
Carefully pry the display with its parts out of the case.
After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Hi! I cannot find a way to insert the plastic opening tool. Any suggestions on how I can create a gap to start. Everything seems quit rigid.
Also, where will I find your reply.
vbr/lars.skoldebring@gmail.com
Hi Lars, you might want to use a suction handle to lift the display and create a small gap to insert the plastic tool. If you don’t have a suction handle you can “build” a handle with tape that you stick onto the display in a shape similar to this —> __∏__ (also you may want to edit your post and remove your email address ;) )
Hi,
I’m stuck at this step for about two hours… There’s nothing I can do to open the case. Tried all kinds of opening tools and a suction handle. There is no gap at all between the display and the body. How can anything be inserted into a gap that practically does not exist? Please help.
Sorry to hear that. You could try and lift the display by using a suction cup and pull to create a small gap for a tool to get in.
Swing open the phone backwards.
Use a spudger to disconnect the power- and volume button flex cable.
Thanks JaL, of course it is.
Remove the two Phillips #00 screws.
Use a spudger to disconnect the battery, the interconnect and the display flex cable.
Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
Use an iOpener to loosen the remaining adhesive.
It wasn’t easy to find the piece to pull. It was a black label, folded and stuck to the battery
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
Insert an opening pick or spudger beneath the battery and carefully pry it out.
Remove the battery.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
75 участников успешно повторили данное руководство.
16 Комментариев
Thanks for posting this this give me new ideas.
Facile comme bonjour. Les outils que j'avais reçu avec la batterie étaient de piètre qualité, j'ai donc utilisé des mini-spatules utilisées pour lisser les joints en silicone, c'est pile la consistance voulue pour décoller le dos et la batterie, ni trop ferme ni trop souple.
Easy fix, thanks a lot.
Eccellente guida peccato che una volta montata la nuova batteria in cellulare si sente che si accende la il display rimane buio, controllato connessioni ma sono tutte ok e display sempre spento, cosa può essere?
Adriano
Per prima cosa puoi provare a controllare il cavo più a sinistra (quello del display). Accertati che non abbia qualche tipo di piega e che anche i piccoli pin dei contatti non siano piegati.
albertob -
stessa cosa, avete poi trovato soluzioni?
Hello,
The battery seems connected but nothing appears on my screen.
Do you have any idea of where it comes from ?
i have the same issue. Any comment on this?
ottima guida
Easy to handle, great explanation and perfect equipment!
I did it! thank you so much Mr. Schnabelrauch. I feel proud
Hi Antoine,
happy to hear and have fun with your new battery life :)
thanks, only the battery was a problem with all the glue
Hi there, I had a battery that I just replaced that was swollen and device would just power cycle. New battery fixed that issue but now phone will not charge. Any tips?
Das Honor 9 hat an der Unterkante keine Schrauben.
Wie ist das Honor 9 zu öffnen?
Michael Tuschek - Ответить
Vielleicht beantwortet diese Anleitung deine Frage ;)
Tobias Isakeit -
Hi, my P10 does not have screws, just two tiny holes. Do I push in here to unfasten? Einar, Norway
Einar Ryvarden - Ответить
Hi Einar Ryvarden,
in case you bought a used or refurbished phone, someone might have forgotten to put them back in. Since you have holes at the bottom edge next to the charging port this is likely. You can try to start with step 2 and see if you can lift the phone assembly (don’t forget to remove the SIM tray first). As far as I know there is no version of the regular Huawei P10 with no screws. However you there are none in the P10 lite and in the P10 plus, maybe one of the opening procedures for those phones might help you.
Dominik Schnabelrauch -
