Введение
Use this guide to remove and replace the display in your Huawei P10 smartphone.
To protect your eyes from glass shreds and get a better grip to open the phone you might want to apply some tape onto the screen.
When reassembling apply new adhesive where it is necessary.
Выберете то, что вам нужно
Switch off your phone.
Remove the two Pentalobe P2 screws at the bottom.
Remove the SIM card tray.
Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
Carefully pry the display with its parts out of the case.
After you pried out the bottom end, use the opening tool to open the clamps on both sides.
Swing open the phone backwards.
Use a spudger to disconnect the power- and volume button flex cable.
Инструмент, используемый на этом этапе:Tweezers$4.99
Remove the two Phillips #00 screws.
Use tweezers to remove both metal plates.
Use a spudger to disconnect the interconnect, the battery and the display flex cable.
Remove the four Phillips #00 screws.
Use Tweezers to remove the metal plate.
Use a spudger to disconnect the main flex cable.
Use tweezers to disconnect the antenna cable and pull it out of the clamp holding it down to the charging board.
Use a spudger to carefully pry out the loudspeaker. There is some adhesive underneath so it might be a little bit sticky. You can use an iOpener to loosen it.
Remove the loudspeaker.
Remove the antenna cable if you haven't already.
Use tweezers to remove the interconnect cable.
Use an iOpener to loosen the adhesive beneath the display. Especially take care of the upper and lower part of the display.
Insert the tip of an opening pick between the display and the midframe on the bottom of the phone, near the home button.
Slide the opening pick along the bottom edge, to cut the adhesive.
Slide the opening pick to the bottom right corner and leave it there.
Insert another opening pick under the screen on the bottom left corner.
Carefully pull the display assembly away from the frame.
Remove the display assembly.
23 человек успешно провели ремонт по этому руководству.
4 Комментарии к руководству
Any advice which adhesive to use? I’ve seen a russian replacement video, it looked like the guy was using some kind of silicone.
Little late but maybe this?
I used B-7000 glue. It enables you to release the screen when a second replacement is needed.
Assuming I purchase a screen off of ebay, and replace it using this method, will the touch id still work?
