Введение
In this guide we show you how to replace the headphone jack in your Huawei P10 Plus smartphone.
Выберете то, что вам нужно
Use an iOpener to loosen the adhesive beneath the display, focusing on the upper and lower part of the display.
Use an opening pick, or iFlex, to separate the adhesive on all sides of the display.
Place a suction cup, or iSclack, on the upper portion of the phone and lift the display off the midframe.
Don't remove the display, the cable is trapped under a bracket screwed to the phone. You can flip the display to lay it down without straining the cable, or simply hold it in the next steps.
Remove the 3.3 mm-long Phillips screw securing the display flex connector bracket.
Инструмент, используемый на этом этапе:Tesa 61395 Tape$5.99
Open the metal bracket that covers the display flex cable.
Use a spudger to disconnect the display flex cable.
Remove the display.
Remove the 13 Phillips #00 screws.
Remove the metal shield which holds down the display flex connector.
Remove the SIM card tray.
Use the pointed end of a spudger to pry out the mid frame until you can get a good grip.
Disconnect the headphone jack flex cable with a spudger.
Use an iOpener to loosen the adhesive beneath the headphone jack.
Remove the headphone jack.
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Еще один человек закончил это руководство.
