Введение
Use this guide if the Huawei Union’s camera will not work properly.
Выберете то, что вам нужно
Wedge your thumb nail, or the flat end of a spudger, into the bottom left corner and pry off.
Use the flat end of a spudger, or fingernail, to lift up the battery and pull out.
Remove the thirteen 3mm Phillips #00 screws from the back panel.
Use the flat end of a spudger to disconnect the camera from the motherboard.
Pull the camera out to remove.
