Введение
Use this guide to replace the motherboard & daughterboard in the Huawei Watch GT 2 (46 mm).
Выберете то, что вам нужно
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Insert the edge of a spudger into the middle loudspeaker opening at the top edge of your watch.
Use the spudger to pry up the back cover assembly of your Huawei watch GT 2.
Use a pair of tweezer to remove the metal shield covering the multi-purpose flex connector.
Use the flat end of a spudger to pry up and disconnect the multi-purpose flex connector.
Separate the back cover assembly from the watch case.
Use the flat end of a spudger to pry up and disconnect the main flex cable from the daughterboard.
Use the flat end of a spudger to pry up and disconnect the watch buttons flex cable from the daughterboard.
Use the flat end of a spudger to lift the right edge of the daughterboard off its socket.
Use a pair of tweezers to remove the metal shield covering the display connectors.
Use the flat end of a spudger to pry up and disconnect the left display flex cable.
Use the flat end of a spudger to pry up and disconnect the right display flex cable.
Use a pair of tweezers to carefully peel the watch button flex cable off the motherboard and fold it to the side.
10 участников успешно повторили данное руководство.
4 Комментариев
Fine, the step 15 is quite difficult, because there is a pin into the U near the edge ... I did have to remove by the middle of the shield and pry It
Good job
