Huawei Watch GT 3 Motherboard & Daughterboard Replacement
Выберете то, что вам нужно
  1. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the watch band: шаг 1, изображение 1 из 1
    • Before starting repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Unfasten the back cover screws: шаг 2, изображение 1 из 1
    • Remove the four 3.7 mm-long Torx T2 screws securing the back cover.
  3. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Pry up the rear panel: шаг 3, изображение 1 из 2 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Pry up the rear panel: шаг 3, изображение 2 из 2
    • Insert the edge of a spudger into the the loudspeaker opening at the bottom edge of your watch.
    • When prying up the back cover put a finger on top or the edge of it and hold it down. Too much force during the prying procedure may lead to popping off the back cover too quickly and tearing the rear panel assembly cable.
    • The plastic clamps holding the back cover in place sit very tight and may require some force during the prying procedure.
    • Use a spudger to pry up the rear panel of your Huawei watch GT 3.
    • Don't try to remove the back cover assembly all the way yet, it's still connected to the daughterboard.
  4. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Swing open the rear panel assembly: шаг 4, изображение 1 из 2 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Swing open the rear panel assembly: шаг 4, изображение 2 из 2
  5. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Peel off the black tape: шаг 5, изображение 1 из 2 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Peel off the black tape: шаг 5, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    • Use a pair of tweezers to peel the black tape off the battery connector bracket.
  6. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Unfasten the battery connector bracket screw: шаг 6, изображение 1 из 1
    • Remove the singe 2.2 mm-long Phillips screw securing the battery connector bracket.
  7. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the battery connector bracket: шаг 7, изображение 1 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the battery connector bracket: шаг 7, изображение 2 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the battery connector bracket: шаг 7, изображение 3 из 3
    • Use a pair of tweezers to remove the battery connector bracket.
    • The connector bracket is secured with a small metal hook next to the screw recess. This hook sits very tight und you might need to bend it a little to the side to remove the bracket.
  8. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the back cover assembly: шаг 8, изображение 1 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the back cover assembly: шаг 8, изображение 2 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the back cover assembly: шаг 8, изображение 3 из 3
    • Use a spudger to disconnect the rear panel assembly cable by prying the connector straight up from its socket.
    • Remove the rear panel assembly.
  9. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Unfasten the daughterboard screw: шаг 9, изображение 1 из 1
    • Remove the singe 2.2 mm-long Phillips screw securing the daughterboard.
  10. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the motherboard flex cable: шаг 10, изображение 1 из 2 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the motherboard flex cable: шаг 10, изображение 2 из 2
    • Use a spudger to disconnect the motherboard flex cable by prying the connector straight up from its socket.
  11. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the daughterboard: шаг 11, изображение 1 из 2 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the daughterboard: шаг 11, изображение 2 из 2
    • Use a pair of tweezers to remove the daughterboard.
  12. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the display connector bracket: шаг 12, изображение 1 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the display connector bracket: шаг 12, изображение 2 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the display connector bracket: шаг 12, изображение 3 из 3
    • Use a pair of tweezers to remove the display connector bracket.
  13. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Unfasten the motherboard screws: шаг 13, изображение 1 из 1
    • Remove the three 2.2 mm-long Phillips screw securing the motherboard.
  14. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the display and digitizer: шаг 14, изображение 1 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the display and digitizer: шаг 14, изображение 2 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the display and digitizer: шаг 14, изображение 3 из 3
    • Use a spudger to disconnect the display and digitizer cables by prying the connectors straight up from their sockets.
  15. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the watch button cable: шаг 15, изображение 1 из 2 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Disconnect the watch button cable: шаг 15, изображение 2 из 2
    • Use a spudger to disconnect the watch button cable by prying the connector straight up from its socket.
  16. Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the motherboard: шаг 16, изображение 1 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the motherboard: шаг 16, изображение 2 из 3 Huawei Watch GT 3 Motherboard & Daughterboard Replacement, Remove the motherboard: шаг 16, изображение 3 из 3
    • Use a pair of tweezers to lift the mother board out of the watch frame and remove it.
Заключение
If possible, turn on your device and test your repair before installing new adhesive and resealing.
Еще один человек закончил это руководство.
Dominik Schnabelrauch
Участник с: 11/23/16
230 161 Репутация
Автор 682 руководств
Команду
iFixit Участник iFixit
Staff
118 членов
Автор 19 537 руководств
2 Комментариев
Where to buy Huawei gt3 daughter board?
HamoodJ - Ответить
Hi my connector cabel is broken where do i find a new backcover with battery ens connector cabel?
Huawei Watch GT3 Pro
//Hampus
Hampus Akvist - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 9
За последние 7 дней: 58
За последние 30 дней: 198
За всё время: 3,578
