IBM ThinkPad T41 Trackpad Replacement
Выберете то, что вам нужно
    1. IBM ThinkPad T41 Trackpad Replacement, Keyboard: шаг 1, изображение 1 из 1
      • Close the screen and turn the closed laptop over.
      • Remove all 17 screws on the bottom of the computer.
      • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
      • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
      Спросите у FixBot
      Добавить комментарий
    2. IBM ThinkPad T41 Trackpad Replacement: шаг 2, изображение 1 из 1
      • Remove the extra RAM cover, by lifting where the screw was and pulling out.
      Спросите у FixBot
    3. IBM ThinkPad T41 Trackpad Replacement: шаг 3, изображение 1 из 1
      • Turn the laptop right side up and open the screen.
      • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
      • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
      Спросите у FixBot
    4. IBM ThinkPad T41 Trackpad Replacement: шаг 4, изображение 1 из 1
      • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
      • Remove the keyboard.
      Спросите у FixBot
    1. IBM ThinkPad T41 Trackpad Replacement, Trackpad: шаг 5, изображение 1 из 1
      • Close the laptop and turn it over.
      • Remove the five plastic stickers covering the screws on the front edge of the case.
      • In order to reuse the stickers, remove them carefully.
      Спросите у FixBot
    2. IBM ThinkPad T41 Trackpad Replacement: шаг 6, изображение 1 из 1
      • Unscrew the five screws that were hidden by the stickers.
      Спросите у FixBot
    3. IBM ThinkPad T41 Trackpad Replacement: шаг 7, изображение 1 из 1
      • Turn the computer right side up and open the screen.
      • Lift the trackpad assembly by placing hands on both edges and then pull towards you till it is free of the case.
      • Be careful of the ribbon cable underneath. It may tear if the trackpad is pulled too vigorously.
      Спросите у FixBot
    4. IBM ThinkPad T41 Trackpad Replacement: шаг 8, изображение 1 из 1
      • Unplug the trackpad’s ribbon cable by pulling on the white plastic tab.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Marissa Blustein
Участник с: 04/16/10
543 Репутация
Автор 12 руководств
Команда
Cal Poly, Team 7-8, Maness Spring 2010 Участник Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 членов
Автор 55 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 18
За последние 30 дней: 40
За всё время: 5,143
