Введение
Replace the light tunnel if experiencing dark bands across or on the edges of the screen.
For this project you'll need a can of compressed air to clean the inside if it's dirty. You'll also need a Torx screwdriver and a metal spudger.
Выберете то, что вам нужно
Flip the projector on its back.
Use the Phillips #2 screwdriver to remove the (4) four 2 cm gold screws.
Use the Phillips #2 screwdriver to remove the (3) three 1 cm silver screws.
Turn the projector, facing the back cable board towards you.
Using the Phillips #0 screwdriver, remove the (3) three 1.0 cm silver screws on the back panel.
Gently take off back cable panel.
Turn the projector so the front side with the lens is facing you.
Gently pry the both of the grey lens rings using the metal spudger.
Now that the screws have been removed, proceed with the removal of the outer panel.
Gently remove the front lens panel.
Being careful not to pull the wires inside the projector, gently lift the top panel off the projector.
With the lens facing you, remove the following screws:
Using the Phillips #1 screwdriver, remove the (3) three 1.25 cm gold screws holding the metal grate between the color wheel unit and the bulb.
Using the Phillips #1 screwdriver, remove the (2) two 2 cm gold screws on the right side of the lens house.
Using the Phillips #1 screwdriver and a bent driver, remove the (4) four 2 cm screws on the back of the lens house.
Using a Phillips #0 screwdriver remove the three 1 cm black screws from the lens house.
Remove the lens unit.
Using the Phillips #0 head, unscrew the four 1 cm black screws.
Remove the metal casings holding the tunnel in place.
Using the Phillips #0 head, unscrew the black 0.5 cm screw on the bottom of the lens house.
Remove the light tunnel.
To reassemble the device, follow these instructions in reverse order.
