Insignia Flex 10.1 Screen Replacement
Выберете то, что вам нужно
    1. Insignia Flex 10.1 Screen Replacement, Screen: шаг 1, изображение 1 из 1
      • Please be aware that removing the rear panel from the back of the Flex 10.1 may cause damage to the rear panel.
      Спросите у FixBot
      Добавить комментарий
    2. Insignia Flex 10.1 Screen Replacement: шаг 2, изображение 1 из 2 Insignia Flex 10.1 Screen Replacement: шаг 2, изображение 2 из 2
      • The rear panel is secured to the front case by 26 clips attached to the rear panel. These clips lock onto small tabs machined into the front case.
      • To help in visualization, the 9 clips boxed in orange are located on the same side as the volume buttons.
      • To free the tabs, they must be pushed toward the center of the device. When using the plastic opening tool to free the rear panel, be sure to work the tool at the location of these clips.
      • Remove back cover by inserting a plastic opening tool along the edge of the device to release the clips.
      Спросите у FixBot
    3. Insignia Flex 10.1 Screen Replacement: шаг 3, изображение 1 из 1
      • Opening the Flex 10.1 can be challenging. Don't get discouraged if it takes multiple attempts before the Flex 10.1 is opened.
      • Insert the plastic opening tool into the seam between the front case and the rear panel of the Flex 10.1.
      • Gently enlarge the existing gap by pressing and wiggling the plastic opening tool into the gap near each of the clips attached to the rear case, pushing the clips toward the center of the device until the clips have been freed.
      • Repeat the same procedure to free all clips around the Flex 10.1.
      Спросите у FixBot
    4. Insignia Flex 10.1 Screen Replacement: шаг 4, изображение 1 из 1
      • After ensuring all clips are free, separate the two halves of the Flex 10.1.
      • The rear panel is now free from the Flex 10.1.
      Спросите у FixBot
    5. Insignia Flex 10.1 Screen Replacement: шаг 5, изображение 1 из 1
      • With the rear panel removed, the back side of the Flex 10.1 should look like this.
      Спросите у FixBot
    6. Insignia Flex 10.1 Screen Replacement: шаг 6, изображение 1 из 1
      • Peel off the tape covering the two connections labeled in red.
      Спросите у FixBot
    7. Insignia Flex 10.1 Screen Replacement: шаг 7, изображение 1 из 3 Insignia Flex 10.1 Screen Replacement: шаг 7, изображение 2 из 3 Insignia Flex 10.1 Screen Replacement: шаг 7, изображение 3 из 3
      • Remove the ribbon cable by lifting up on the connection with a plastic opening tool and pulling out the ribbon cable.
      Спросите у FixBot
    8. Insignia Flex 10.1 Screen Replacement: шаг 8, изображение 1 из 3 Insignia Flex 10.1 Screen Replacement: шаг 8, изображение 2 из 3 Insignia Flex 10.1 Screen Replacement: шаг 8, изображение 3 из 3
      Спросите у FixBot
    9. Insignia Flex 10.1 Screen Replacement: шаг 9, изображение 1 из 2 Insignia Flex 10.1 Screen Replacement: шаг 9, изображение 2 из 2
      • Use a Phillips #0 screwdriver to unscrew the 17 screws labeled in red.
      Спросите у FixBot
    10. Insignia Flex 10.1 Screen Replacement: шаг 10, изображение 1 из 2 Insignia Flex 10.1 Screen Replacement: шаг 10, изображение 2 из 2
      • Separate the whole assembly from the screen, being careful and ensuring you removed everything necessary.
      Спросите у FixBot
    11. Insignia Flex 10.1 Screen Replacement: шаг 11, изображение 1 из 1
      • With the screws and white plastic cover removed, the screen and glass panel is exposed.
      Спросите у FixBot
    12. Insignia Flex 10.1 Screen Replacement: шаг 12, изображение 1 из 2 Insignia Flex 10.1 Screen Replacement: шаг 12, изображение 2 из 2
      • Peel back the ribbon cable resting on the screen.
      Спросите у FixBot
    13. Insignia Flex 10.1 Screen Replacement: шаг 13, изображение 1 из 3 Insignia Flex 10.1 Screen Replacement: шаг 13, изображение 2 из 3 Insignia Flex 10.1 Screen Replacement: шаг 13, изображение 3 из 3
      • Remove the tape covering the connection.
      • Disconnect the ribbon cable from the screen by lifting up on the connection and pulling out the ribbon cable.
      Спросите у FixBot
    14. Insignia Flex 10.1 Screen Replacement: шаг 14, изображение 1 из 3 Insignia Flex 10.1 Screen Replacement: шаг 14, изображение 2 из 3 Insignia Flex 10.1 Screen Replacement: шаг 14, изображение 3 из 3
      • The screen is now free. Lift the screen out of the glass panel. The screen can now be replaced.
      Спросите у FixBot
Заключение
4 человек успешно провели ремонт по этому руководству.
William Boyden
Участник с: 03/07/16
388 Репутация
Автор 3 руководств
Команда
UMass Dartmouth, Team 2-1, Isaacson Spring 2016 Участник UMass Dartmouth, Team 2-1, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G1
3 членов
Автор 11 руководств
2 Комментарии к руководству
What % is there that you'll damage the board in the process of trying to fix the screen?
pepper6540.pah - Ответить Поделиться
If it cost $100 to take you a repair shop i'd probably try myself seeing that i only payed 100 for it, and if it don't work I'm still in same boat with a broke sceen on my Insignia Flex
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 13
За последние 30 дней: 37
За всё время: 8,296
