Ivation IVWPDC20Y Flash Bulb Replacement
Выберете то, что вам нужно
    1. Ivation IVWPDC20Y Flash Bulb Replacement, Flash Bulb: шаг 1, изображение 1 из 1
      • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
      Спросите у FixBot
      Добавить комментарий
    2. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 2, изображение 1 из 1
      • Apply a plastic opening tool to each of the corners and gently remove the casing
      • The front casing is held down by adhesive and may require additional work to remove
      • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
      Спросите у FixBot
    3. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 3, изображение 1 из 1
      • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
      Спросите у FixBot
    4. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 4, изображение 1 из 1
      • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
      • These screws are very small and easy to strip so apply consistent pressure when removing them
      Спросите у FixBot
    5. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 5, изображение 1 из 1
      • Pry off back outer casing using the black spudger or the blue prying tools
      Спросите у FixBot
    6. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 6, изображение 1 из 1
      • Carefully remove the screen from the silver casing using a prying tool or the black spudger
      • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
      Спросите у FixBot
    7. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 7, изображение 1 из 1
      • Gently push out the pins holding the orange tape down using the pointy end of the spudger
      • Screen and orange tape should slip out as a whole
      Спросите у FixBot
    8. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 8, изображение 1 из 1
      • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
      Спросите у FixBot
    9. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 9, изображение 1 из 1
      • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver bit
      Спросите у FixBot
    10. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 10, изображение 1 из 1
      • Gently lift the corner of the motherboard out
      • Everything should come out as one component free of the casing
      Спросите у FixBot
    11. Ivation IVWPDC20Y Flash Bulb Replacement: шаг 11, изображение 1 из 1
      • Remove the soldering on the three wires holding the flash bulb
      • The wires are different colors: red, white, and black
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Wendy Jones
Участник с: 02/06/16
225 Репутация
Автор 2 руководств
Команда
USF Tampa, Team 6-6, Eyestone Spring 2016 Участник USF Tampa, Team 6-6, Eyestone Spring 2016
USFT-EYESTONE-S16S6G6
3 членов
Автор 5 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 512
