Введение
The battery will be replaced by dismantling the device, disconnecting the current battery and connecting a new battery.
Выберете то, что вам нужно
Insert the plastic opening tool underneath the mesh top.
Pry the cover open.
Remove the four 5mm Phillips screws that hold down the speaker in place.
Remove the two 6mm Phillips screws that hold down the plastic casing.
Инструмент, используемый на этом этапе:Halberd Spudger$2.99
Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
Pull the speaker up and out.
After removing all of the screws from the plastic cover, remove it by pulling up and out.
Remove the three 5mm Phillips screws that hold the motherboard in place.
After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
Инструмент, используемый на этом этапе:Tweezers$4.99
Expose the motherboard and battery and place in a position that will be easy to access and work with.
Use tweezers to remove the battery's wire from the motherboard at the connection point.
Pull the battery from the motherboard.
Еще один человек закончил это руководство.
