Введение
The rubber base may be worn and in need of replacement or to gain access to the underside of the device . Depending on objectives, a new rubber base may be applied or the used base may be reapplied.
Выберете то, что вам нужно
Use the plastic opening tool to help peel the rubber cover off the base.
Peel off the rest of the rubber base by hand.
Еще один человек закончил это руководство.
