Jazz HDV178 Camcorder Power Button Replacement
Выберете то, что вам нужно
    1. Jazz HDV178 Camcorder Power Button Replacement, Back Cover: шаг 1, изображение 1 из 1
      • On the back of the camcorder, the side opposite of the flip-out screen, there is a section of grooved plastic with a small arrow.
      • Press down on the grooved plastic with your thumbs.
      • Push the back cover in the direction indicated by the small arrow on the grooved plastic. The back cover should slide right off.
      Спросите у FixBot
      Добавить комментарий
    1. Jazz HDV178 Camcorder Power Button Replacement, Battery: шаг 2, изображение 1 из 1
      • Once you have the back cover off, the camcorder should look like this.
      • Look on the battery for a model number to assure that you acquire the correct replacement part.
      • The camcorder model number is located in the red box. Verify that you have a Jazz HDV178.
      Спросите у FixBot
    2. Jazz HDV178 Camcorder Power Button Replacement: шаг 3, изображение 1 из 1
      • Take the battery out by pulling up on the bottom of the battery. You should be pulling from the side of the camera where the wrist strap is attached.
      Спросите у FixBot
    1. Jazz HDV178 Camcorder Power Button Replacement, Housing: шаг 4, изображение 1 из 1
      • Remove the camera mount by unscrewing the 4.5 mm screw in the hole.
      • This is the bottom of the camcorder near where the wrist strap connects.
      Спросите у FixBot
    2. Jazz HDV178 Camcorder Power Button Replacement: шаг 5, изображение 1 из 1
      • Remove the 4.5 mm screw located near the battery slot.
      Спросите у FixBot
    3. Jazz HDV178 Camcorder Power Button Replacement: шаг 6, изображение 1 из 1
      • Break the glue that attaches the lens cover to the camcorder by sliding the plastic prying tool beneath the circumference of the part.
      • After the glue is broken, remove the lens cover.
      Спросите у FixBot
    4. Jazz HDV178 Camcorder Power Button Replacement: шаг 7, изображение 1 из 1
      • Use a small plastic pry tool to gently pry off the silver strip on the top of the camera.
      • Make sure to run the tool under the outline of the strip as you pry it off so the plastic does not snap.
      Спросите у FixBot
    5. Jazz HDV178 Camcorder Power Button Replacement: шаг 8, изображение 1 из 3 Jazz HDV178 Camcorder Power Button Replacement: шаг 8, изображение 2 из 3 Jazz HDV178 Camcorder Power Button Replacement: шаг 8, изображение 3 из 3
      • Locate the side of the camcorder beneath the lens and on the opposite side of the wrist strap.
      • Remove the silver strip using the same process as the previous step.
      • Remove the two 4 mm screws that were hidden under the cover.
      Спросите у FixBot
    6. Jazz HDV178 Camcorder Power Button Replacement: шаг 9, изображение 1 из 3 Jazz HDV178 Camcorder Power Button Replacement: шаг 9, изображение 2 из 3 Jazz HDV178 Camcorder Power Button Replacement: шаг 9, изображение 3 из 3
      • Pry off the rubbery cap, which covers the buttons. Use the same process as the previous two steps.
      • Slide your prying tool underneath the entire cover to ensure that the glue breaks cleanly and the cover does not snap.
      Спросите у FixBot
    7. Jazz HDV178 Camcorder Power Button Replacement: шаг 10, изображение 1 из 1
      • Remove the three combined buttons so they are not misplaced.
      Спросите у FixBot
    8. Jazz HDV178 Camcorder Power Button Replacement: шаг 11, изображение 1 из 2 Jazz HDV178 Camcorder Power Button Replacement: шаг 11, изображение 2 из 2
      • Using a firm hold on both sides of the camcorder, gently pull apart the two halves. Pressure should be evenly distributed across the entire device.
      • If the camcorder does not come apart easily, double check that all of the screws are removed. Return to the previous steps for screw removal if you find a screw that is still attached.
      Спросите у FixBot
    1. Jazz HDV178 Camcorder Power Button Replacement, Lens: шаг 12, изображение 1 из 2 Jazz HDV178 Camcorder Power Button Replacement, Lens: шаг 12, изображение 2 из 2
      • Remove the big headed 3.5 mm screw that holds the lens in place.
      Спросите у FixBot
    2. Jazz HDV178 Camcorder Power Button Replacement: шаг 13, изображение 1 из 2 Jazz HDV178 Camcorder Power Button Replacement: шаг 13, изображение 2 из 2
      • Grab the plastic part covering the lens and gently wiggle it out of place to uncover the lens.
      • Be sure to note how the part is attached so that you can replace it correctly.
      Спросите у FixBot
    1. Jazz HDV178 Camcorder Power Button Replacement, Removing Speaker: шаг 14, изображение 1 из 2 Jazz HDV178 Camcorder Power Button Replacement, Removing Speaker: шаг 14, изображение 2 из 2
      • Remove the 4 mm screws holding the speaker onto the motherboard.
      • Once the speaker itself is unscrewed, remove the 4 mm silver screws that hold the connection wires to the LCD Display.
      Спросите у FixBot
    1. Jazz HDV178 Camcorder Power Button Replacement, Motherboard: шаг 15, изображение 1 из 1
      • Remove the four Phillips head screws attaching the motherboard to the housing.
      Спросите у FixBot
    2. Jazz HDV178 Camcorder Power Button Replacement: шаг 16, изображение 1 из 1
      • Remove the individual 4mm screw under the top button to release the motherboard from the housing.
      Спросите у FixBot
    3. Jazz HDV178 Camcorder Power Button Replacement: шаг 17, изображение 1 из 1
      • Using care, lift the motherboard from the plastic housing.
      • This step requires patience to ensure no delicate components are damaged.
      Спросите у FixBot
    1. Jazz HDV178 Camcorder Power Button Replacement, Power Button: шаг 18, изображение 1 из 2 Jazz HDV178 Camcorder Power Button Replacement, Power Button: шаг 18, изображение 2 из 2
      • Once you removed the motherboard, remove the clear rubber button.
      • Use rubbeing alcohol on a Q-tip to clean the surface.
      • Allow to dry and wipe with a clean Q-tip.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
timothy
Участник с: 01/28/11
354 Репутация
Автор 3 руководств
Команду
Cal Poly, Team 7-34, Regan Winter 2011 Участник Cal Poly, Team 7-34, Regan Winter 2011
CPSU-REGAN-W11S7G34
4 членов
Автор 73 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 16
За последние 30 дней: 76
За всё время: 1,057
