Jazz UltraTab C855 Battery Replacement
Выберете то, что вам нужно
    1. Jazz UltraTab C855 Battery Replacement, Back Cover: шаг 1, изображение 1 из 1
      Спросите у FixBot
      Добавить комментарий
    2. Jazz UltraTab C855 Battery Replacement: шаг 2, изображение 1 из 1
      • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
      Спросите у FixBot
    1. Jazz UltraTab C855 Battery Replacement, Battery: шаг 3, изображение 1 из 1
      • Remove the yellow tape from the sides of the battery, and the surrounding components.
      Спросите у FixBot
    2. Jazz UltraTab C855 Battery Replacement: шаг 4, изображение 1 из 1
      • Cut the pos(+) and neg (-) wires that connect the battery to the device using wire cutters.
      • Cut the wires towards the middle. During installation of your new battery these wires will be stripped back and soldered or crimped to reattach.
      Спросите у FixBot
    3. Jazz UltraTab C855 Battery Replacement: шаг 5, изображение 1 из 1
      • Using a plastic opening tool or spudger, slowly pry the battery away from the board.
      • The battery is secured to the device with adhesive.
      • Metal spudgers can puncture an unprotected battery, potentially causing a fire. When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Спросите у FixBot
    4. Jazz UltraTab C855 Battery Replacement: шаг 6, изображение 1 из 1
      • Use a two sided adhesive to secure the new battery in place.
      • Solder or crimp the wires back together to reattach to the motherboard.
      • Replace any yellow tape that you removed at the beginning to secure the wires back in place.
      Спросите у FixBot
Заключение
Cory Hodge
Участник с: 09/14/15
201 Репутация
Автор 2 руководств
Команда
IUPUI, Team 1-3, Baechle Fall 2015 Участник IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 членов
Автор 10 руководств
1 Комментарий к руководству
Very good instructions.....but where do I buy the repkacement battery from?
fremontmyers - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 4
За последние 30 дней: 22
За всё время: 790
