Jazz UltraTab C855 Screen Replacement
Выберете то, что вам нужно
    1. Jazz UltraTab C855 Screen Replacement, Back Cover: шаг 1, изображение 1 из 1
      Спросите у FixBot
      Добавить комментарий
    2. Jazz UltraTab C855 Screen Replacement: шаг 2, изображение 1 из 1
      • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
      Спросите у FixBot
    1. Jazz UltraTab C855 Screen Replacement, Motherboard: шаг 3, изображение 1 из 1
      • Remove the two pieces of tape securing the ribbon cables to the motherboard.
      Спросите у FixBot
    2. Jazz UltraTab C855 Screen Replacement: шаг 4, изображение 1 из 1
      • Remove the 3 screws at the top of the motherboard.
      Спросите у FixBot
    3. Jazz UltraTab C855 Screen Replacement: шаг 5, изображение 1 из 1
      • Using a plastic prying tool, lift open the latch that secures the ribbon cable next to the speaker.
      • Pull the ribbon cable out of its connector on the motherboard.
      Спросите у FixBot
    4. Jazz UltraTab C855 Screen Replacement: шаг 6, изображение 1 из 1
      • Use a plastic prying tool to disconnect the other ribbon cable from the motherboard. This cable belongs to the device's cameras.
      Спросите у FixBot
    5. Jazz UltraTab C855 Screen Replacement: шаг 7, изображение 1 из 1
      • Disconnect the large ribbon cable from the motherboard. Do this by unlocking the tabs on each side of the connector.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      Спросите у FixBot
    6. Jazz UltraTab C855 Screen Replacement: шаг 8, изображение 1 из 1
      • Snip the two sets of wires that are attached to the motherboard. Cut the wires as close to the board as possible. This will leave plenty of length to reattach the wires to the new board.
      • Skip this step if you are only removing the motherboard to replace the screen.
      • During reassembly, we recommend soldering or crimping the wires away from the motherboard contacts. You should avoid soldering directly to the motherboard unless absolutely necessary. To learn more about soldering, check out iFixit's Soldering Skills Guide
      Спросите у FixBot
    1. Jazz UltraTab C855 Screen Replacement, Screen: шаг 9, изображение 1 из 1
      • Remove the two screws securing the speaker using the Phillips #000 Screwdriver.
      • Remove the speaker and set it aside.
      Спросите у FixBot
    2. Jazz UltraTab C855 Screen Replacement: шаг 10, изображение 1 из 1
      • Carefully pry the display from the 9 white tabs that secure the display to the screen.
      • You may also need to peel back a piece of tape on one side to completely remove the assembly.
      • Be careful when removing the screen. A broken screen may produce shards of glass.
      Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Peter Daum
Участник с: 09/16/15
174 Репутация
1 руководство автора
Команда
IUPUI, Team 1-3, Baechle Fall 2015 Участник IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 членов
Автор 17 руководств
1 Комментарий к руководству
Are the internal components glued to the back of the display? Is it absolutely ne essay to cut the wires connecting the battery?
Rongwey - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 6
За последние 30 дней: 22
За всё время: 1,013
