Kindle 3 Battery Replacement
Выберете то, что вам нужно
  1. Kindle 3 Battery Replacement, Remove Rear Cover: шаг 1, изображение 1 из 3 Kindle 3 Battery Replacement, Remove Rear Cover: шаг 1, изображение 2 из 3 Kindle 3 Battery Replacement, Remove Rear Cover: шаг 1, изображение 3 из 3
    • Turn the device upside-down and insert a pry tool between the two case pieces.
    • On the left side just below the buttons there's a delicate ribbon cable that's part of the screen assembly and may be severed by a pry tool. (This is shown in the third photo, it's where the tool is pointing.) Regardless of where you start, stay clear of this area!
    • If you are having trouble getting an initial gap to pry from, run the flat edge of the pry tool along the front-to-back plate seam until it slips into a gap. You can also flex the device slightly and work a tool into one of the lower corners, which have a lot of empty space behind them rather than fragile components.
    • Looking at the back face, another safe place to start is on the right side just below the page turn buttons. (Note the green arrow in the board photo, which is rotated 90 degrees counter-clockwise.) The tool goes between the lower button and the hinge cover slot. If there isn't a slot there, you're on the wrong side!
    • Do not attempt to pry directly on the page turning buttons.
    • Work the pry tool around the edge of the case, releasing the 18 clips. Don't insert your tool too far, or you may damage components near the edges of the device. The clips are all in the outer edge of the backplate anyway. Note that the clip above the power switch is bigger and stronger than the rest.
    • Pull the rear cover off. The remaining two clips near the center of the back are surprisingly strong, but they face in the same direction so don't just pull up. Instead slide the cover slightly towards the top of device to release them.
    • When reinstalling the back cover, slide the bottom edge into place first, and then press up the sides and along the top until all the clips snap into place.
    Спросите у FixBot
    Добавить комментарий
  2. Kindle 3 Battery Replacement, Release Battery: шаг 2, изображение 1 из 1
    • Unscrew the two silver 4 mm Phillips screws securing the battery connector.
    • Set the screws aside in a safe place -- there are exposed components and it's easy for them to short-circuit something.
    Спросите у FixBot
  3. Kindle 3 Battery Replacement, Replace Battery: шаг 3, изображение 1 из 3 Kindle 3 Battery Replacement, Replace Battery: шаг 3, изображение 2 из 3 Kindle 3 Battery Replacement, Replace Battery: шаг 3, изображение 3 из 3
    • Lift battery out of housing starting at the end that was secured by the screws.
    • Watch out for the odd-shaped silver washers beneath the battery connector (see second photo); they are necessary for proper mating of the electrical contacts when the screws are re-tightened.
    • When reinstalling the battery, make sure the washers are in place. Holding the battery at an angle (see first photo), insert the two retaining tabs on the bottom of the battery into the slots in the case. Then rotate the battery into place and screw down the connector.
    Спросите у FixBot
Заключение
To reassemble your device, follow these instructions in reverse order, paying attention to the reassembly notes in the individual steps.
112 человек успешно провели ремонт по этому руководству.
Allison Monahan
Участник с: 09/08/14
3 154 Репутация
Автор 2 руководств
Команда
CSU Fullerton, Team 1-5, Bruce Fall 2014 Участник CSU Fullerton, Team 1-5, Bruce Fall 2014
CSUF-BRUCE-F14S1G5
4 членов
Автор 16 руководств
25 Комментарии к руководству
Hi Allison Monahan,
thank you very much for yor help! By using your guide I made my nearly 6 years old Kindle Keyboard fixed - great!
Stefan Schiche - Ответить Поделиться
I went to mpfproducts.com and ordered my new battery which came in today. I’ve changed out the battery and my Kindle 3 is now charging. YAHOO!!!
Ruth Kuykendall - Ответить Поделиться
Where did you get the battery? I couldn’t find it on Amazon. Do you have a model number for the battery? Thanks.
sand1k - Ответить Поделиться
The old Amazon link has been removed. There’s now a link at the top of this guide to an eBay vendor that stocks the battery. Good luck!
Jeff Suovanen - Ответить Поделиться
Thanks, Allison and IFIXIT!!! God, I love this site. Cheers, Tom
tombeanhall - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 37
За последние 7 дней: 208
За последние 30 дней: 965
За всё время: 93,617
