Kindle Paperwhite 3rd Generation Battery Replacement
Выберете то, что вам нужно
  1. Kindle Paperwhite 3rd Generation Battery Replacement, Battery: шаг 1, изображение 1 из 3 Kindle Paperwhite 3rd Generation Battery Replacement, Battery: шаг 1, изображение 2 из 3 Kindle Paperwhite 3rd Generation Battery Replacement, Battery: шаг 1, изображение 3 из 3
    • Ensure that the device is turned off before beginning.
    • Gently pry the bezel off the screen using a plastic opening tool. Start at the corners and slide around the edges until you return to your starting point.
    • Be careful if using the metal spudger, as it can scratch the surface of the Kindle.
    Спросите у FixBot
    Добавить комментарий
  2. Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: шаг 2, изображение 1 из 3 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: шаг 2, изображение 2 из 3 Kindle Paperwhite 3rd Generation Battery Replacement, Using caution: шаг 2, изображение 3 из 3
    • Use extreme caution when prying up the bezel. Be careful not to allow your pry tool to fall underneath the display. Look under the cover as you work, separating the display from the adhesive of the bezel.
    • You want to make sure your separator goes through both sides of the bezel over top of the display.
    • The second photo is the layer you want your tool to pass through safely.
    • The third photo is an example of what can go wrong. If this happens your digitizer layer will misread touches and the display is permanently damaged.
    Спросите у FixBot
  3. Kindle Paperwhite 3rd Generation Battery Replacement: шаг 3, изображение 1 из 2 Kindle Paperwhite 3rd Generation Battery Replacement: шаг 3, изображение 2 из 2
    • Unscrew the eleven 3.2 mm Phillips #000 screws surrounding the frame.
    Спросите у FixBot
  4. Kindle Paperwhite 3rd Generation Battery Replacement: шаг 4, изображение 1 из 1
    • Gently lift the mid-frame out of the case with your hands.
    • Lift the side opposite of the power button out first.
    Спросите у FixBot
  5. Kindle Paperwhite 3rd Generation Battery Replacement: шаг 5, изображение 1 из 2 Kindle Paperwhite 3rd Generation Battery Replacement: шаг 5, изображение 2 из 2
    • Unscrew the three 3.0 mm Phillips #000 screws that are securing the battery.
    Спросите у FixBot
  6. Kindle Paperwhite 3rd Generation Battery Replacement: шаг 6, изображение 1 из 1
    • Gently lift the battery from the frame.
    Спросите у FixBot
Заключение
95 человек успешно провели ремонт по этому руководству.
Micah Smart
Участник с: 02/10/16
3 428 Репутация
Автор 3 руководств
Команда
USF Tampa, Team 14-3, Lacy Spring 2016 Участник USF Tampa, Team 14-3, Lacy Spring 2016
USFT-LACY-S16S14G3
4 членов
Автор 14 руководств
23 Комментарии к руководству
Same for 5th Generation ??
PAUL FRIEND - Ответить Поделиться
where can i buy a new battery ?
david horn - Ответить Поделиться
you need a taobao.
lol
kassadin - Ответить Поделиться
They are sold on aliexpress and ebay but the price of battery and postage is not that different from the price of a second hand 3ed Gen Kindle. But then the second hand Kindle will probably need a new battery too so, I am going to get a battery from ebay.
Timothy Takemoto - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 47
За последние 7 дней: 264
За последние 30 дней: 1,103
За всё время: 107,221
