KitchenAid Professional 600 Power Cord Replacement
Выберете то, что вам нужно
  1. KitchenAid Professional 600 Power Cord Replacement, Top Cover: шаг 1, изображение 1 из 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
    Спросите у FixBot
    Добавить комментарий
  2. KitchenAid Professional 600 Power Cord Replacement: шаг 2, изображение 1 из 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
    Спросите у FixBot
  3. KitchenAid Professional 600 Power Cord Replacement: шаг 3, изображение 1 из 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
    Спросите у FixBot
  4. KitchenAid Professional 600 Power Cord Replacement, Speed Selector: шаг 4, изображение 1 из 1
    • Locate the selector switch.
    • Remove the two Phillips #2 screws holding the selector switch in place.
    Спросите у FixBot
  5. KitchenAid Professional 600 Power Cord Replacement: шаг 5, изображение 1 из 3 KitchenAid Professional 600 Power Cord Replacement: шаг 5, изображение 2 из 3 KitchenAid Professional 600 Power Cord Replacement: шаг 5, изображение 3 из 3
    • Unplug the cords attaching the drive motor to the switch.
    • We suggest numbering them left from right so they are reattached to the replacement part in the right order.
    Спросите у FixBot
  6. KitchenAid Professional 600 Power Cord Replacement: шаг 6, изображение 1 из 1
    • Pull out the Selector Switch.
    Спросите у FixBot
  7. KitchenAid Professional 600 Power Cord Replacement, Drive Motor: шаг 7, изображение 1 из 1
    • Remove the two Phillips #2 screws holding the motor in place, located near the fan at the back of the motor.
    • The picture only shows one of the screws. The other screw is located on the exact opposite side of the motor.
    Спросите у FixBot
  8. KitchenAid Professional 600 Power Cord Replacement: шаг 8, изображение 1 из 1
    • Pull upward to remove the motor.
    Спросите у FixBot
  9. KitchenAid Professional 600 Power Cord Replacement, Power Cord: шаг 9, изображение 1 из 1
    • Remove the Phillips #2 screw attaching the green grounding wire to the frame of the mixer.
    Спросите у FixBot
  10. KitchenAid Professional 600 Power Cord Replacement: шаг 10, изображение 1 из 1
    • Remove the three Phillips #2 screws that connect the top portion of the mixer to the "neck" of the mixer.
    Спросите у FixBot
  11. KitchenAid Professional 600 Power Cord Replacement: шаг 11, изображение 1 из 1
    • Remove the top portion of the mixer from the "neck" of the mixer.
    • This will make removing the power cord much easier.
    Спросите у FixBot
  12. KitchenAid Professional 600 Power Cord Replacement: шаг 12, изображение 1 из 1
    • You can now remove the power cord from the mixer.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Luke
Участник с: 04/11/16
1 380 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 25-4, Maness Spring 2016 Участник Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 членов
Автор 20 руководств
2 Комментарии к руководству
So helpful thank you. I've got my mixer cord changer and the mixer is working now. Unfortunately there's always only one speed, high. Any suggestions?
Britter C - Ответить Поделиться
Any idea where I can buy the power cord itself?
Jaeger Amzallag - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 15
За последние 30 дней: 79
За всё время: 7,374
