KitchenAid Professional 600 Worm Gear Replacement
Выберете то, что вам нужно
  1. KitchenAid Professional 600 Worm Gear Replacement, Top Cover: шаг 1, изображение 1 из 1
    • Take out the screw which holds on the silver band using a Phillips #2 screwdriver.
    • Remove the silver band.
    Спросите у FixBot
    Добавить комментарий
  2. KitchenAid Professional 600 Worm Gear Replacement: шаг 2, изображение 1 из 1
    • Remove the four Phillips #2 screws located around the mixer where the band was removed.
    • This picture only shows two of the screw that you need to remove. The other two are on the exact opposite side of the mixer.
    Спросите у FixBot
  3. KitchenAid Professional 600 Worm Gear Replacement: шаг 3, изображение 1 из 1
    • Remove the top of the mixer to reveal the inner parts.
    • The top should lift off, but may not if it is stuck. A sharp strike from the back with the hand may unstick it. It will slide forward about a 3/8 of an inch. Push it back again from the front and it should be free enough to lift.
    Спросите у FixBot
  4. KitchenAid Professional 600 Worm Gear Replacement, Gear Housing Cover: шаг 4, изображение 1 из 1
    • Remove the 4 Phillips #2 screws connecting the black housing cover to the device.
    • Only one of the screws is seen in the picture. The other three are also located around the black housing cover.
    Спросите у FixBot
  5. KitchenAid Professional 600 Worm Gear Replacement: шаг 5, изображение 1 из 1
    • Take off the black housing cover.
    Спросите у FixBot
  6. KitchenAid Professional 600 Worm Gear Replacement, Worm Gear: шаг 6, изображение 1 из 1
    • Remove the Worm Gear.
    • The Worm Gear is the part that is lying horizontal.
    • Remember to apply food safe grease onto your new replacement part before assembling the device back together.
    Спросите у FixBot
Заключение
9 человек успешно провели ремонт по этому руководству.
Luke
Участник с: 04/11/16
1 380 Репутация
Автор 5 руководств
Команда
Cal Poly, Team 25-4, Maness Spring 2016 Участник Cal Poly, Team 25-4, Maness Spring 2016
CPSU-MANESS-S16S25G4
4 членов
Автор 20 руководств
1 Комментарий к руководству
No tiene ningún tornillo a los lado eso es mentira
Guillermo Perez - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 5
За последние 7 дней: 23
За последние 30 дней: 165
За всё время: 22,749
