Введение
Removing the back cover of your Kodak PixPro AZ251 gives you access to the camera's LCD screen and motherboard. This guide will instruct you on how to remove the back cover of your Kodak PixPro AZ251.
Выберете то, что вам нужно
Remove a total of four 5mm JIS #000 screws from around the camera:
Two screws from the right side.
Two screws from the left side.
Open the flash module.
Remove the two 6mm JIS #00 screws found inside of the flash housing.
Use a plastic opening tool to pry apart both halves of the camera.
Remove the back panel.
Еще один человек закончил это руководство.
