Введение
In this guide, you will learn how to repair and replace a loose or faulty shutter button on your Kodak PixPro AZ251.
Выберете то, что вам нужно
Remove a total of four 5mm JIS #000 screws from around the camera:
Two screws from the right side.
Two screws from the left side.
Open the flash module.
Remove the two 6mm JIS #00 screws found inside of the flash housing.
Use a plastic opening tool to pry apart both halves of the camera.
Remove the back panel.
Remove these three JIS #000 screws from the control board:
5mm screw.
4mm screw.
2mm screw.
Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
Pull the orange cable out of the socket.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers, disconnect the orange cable connection at the top of the motherboard.
Turn camera upside down.
Remove the six 2mm JIS #000 screws from the metal base of the shutter button.
While holding the shutter button in place, remove the two 4mm JIS #000 screws from the base.
Remove the plastic base of the shutter button using tweezers by pulling it straight upward.
Remove the shutter button by pulling it out from the bottom side of the top cover.
