LG 47LN5400 LED Replacement
Выберете то, что вам нужно
  1. LG 47LN5400 LED  Replacement, LED: шаг 1, изображение 1 из 1
    Спросите у FixBot
    Добавить комментарий
    • Set up a table large enough to hold the TV face down.
    • Place a soft cloth or towel on the table to protect the LCD display.
    • Remove the screws holding the stand.
    • Remove all the screws hold the back cover and remove the cover.
    • Remove the speakers and the small circuit board in the bottom center (behind the LG logo.)
    • Remove the rectangular plate at the bottom center and carefully remove the 2 ribbon cables connected to the LCD display. Flip up the black retaining clip and gently pull out the cables using the clear plastic tab.
    Спросите у FixBot
    • Flip the TV over, LCD side up.
    • Carefully remove the plastic bezel, gently bending the tabs that hold it the frame.
    • Remove the LCD panel. Caution!' The LCD panel is fragile and breaks easily. Slide a large cardboard sheet under the display and carefully support the panel's weight without any bending. (If it cracks, well, you now have a much more expensive repair problem.)
    • Be sure you have a stable surface large enough to hold the LCD panel.
    Спросите у FixBot
    • Remove the small screws from the four metal frames around the outside of the TV. Be sure to remember each part's location and orientation.
    • Remove the plastic LCD support frame.
    • Remove the diffuser panels, taking care to remember their orientations. You can use a Sharpie pen to mark the lower left corner off all of the panels.
    • Flip the TV on the other side. Remove the LCD panel white plastic standoffs. Pinch the clips together and push the standoff out of the chassis.
    Спросите у FixBot
  2. LG 47LN5400 LED  Replacement: шаг 5, изображение 1 из 1
    • Flip the TV on its back again.
    • Remove the white plastic sheet that covers the LED strips.
    Спросите у FixBot
  3. LG 47LN5400 LED  Replacement: шаг 6, изображение 1 из 2 LG 47LN5400 LED  Replacement: шаг 6, изображение 2 из 2
    • Follow the excellent troubleshooting instructions in the YouTube video:LG No Picture, Screen Flash 47LN5200 47LN5400 47LA6200 47LN5700 47LN5750 47LN5790
    • Take care to unplug the LED power connecter before you test with the power supply!
    • Once you have determined where the failed LEDs are, you have a choice:
    • Purchase the replacement LED strips needed; be sure to order the correct part number. Note there are several part numbers for the various strips.
    • Replace all of the LED strips.
    • Replace the individual LEDs, using the heat gun method shown in the video. This isn't as hard as it looks. But you'll need a steady hand and good vision to properly place the new LED(s).
    • Be sure to remove the two-sided tape from the LED strip before heating!
    • And, replace the removed tape with new double-sided tape.
    Спросите у FixBot
  4. LG 47LN5400 LED  Replacement: шаг 7, изображение 1 из 1
    • Once you have replaced the LED strips (or individual LEDs), test the backlight before you reassemble everything.
    • Plug the LED power connector back in.
    • Plug in the AC power cord. Do all the LEDs now light? If so, congratulations! If not, re-check the LEDs with the power supply.
    Спросите у FixBot
Заключение
2 человек успешно провели ремонт по этому руководству.
Wayne Seltzer
Участник с: 11/09/10
1 862 Репутация
Автор 10 руководств
Команда
Boulder U-Fix-It Clinic Участник Boulder U-Fix-It Clinic
Community
1 член
Автор 20 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 4
За последние 7 дней: 31
За последние 30 дней: 151
За всё время: 8,449
