Введение
This guide will show you how to open up your Blu-ray player and remove the motherboard in order to replace various components of it or the whole unit.
Выберете то, что вам нужно
Remove the three black 3/16” Phillips #2 screws from the backside of the player.
With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
Unhinge the tabs that attach the front panel to the unit:
Two tabs on the disc drive
Two tabs on the left and right side of the player
Three tabs on the underside of the player
Pull panel away from case.
Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
With the front side facing you lift the front of disc drive, slide it toward you and pull out to remove.
Detach the power supply cord from the brown motherboard by pushing the locking clip on the connector, and pulling out.
Remove the power cord from the panel by carefully sliding it upwards from its seating.
Remove the two black 3/16” Phillips #2 screws from the backside of the player.
One screw inbetween the audio/video jacks
One screw to the bottom right of the audio/video jacks
With the backside facing you, pull the bottom of the panel towards you and lift to remove it.
Remove the the two silver 3/16” Phillips #2 screws from the green motherboard.
Remove the one black 3/16” Phillips #2 screw from the brown motherboard
Use both hands to carefully lift the motherboard unit away from the player.
6 человек успешно провели ремонт по этому руководству.
1 Комментарий к руководству
I need Ic htc lm37102 which is on this lg motherboard. How can i get that. I am not able to find
Email Id abhishek.mishra171983@gmail.com
Please let me know if you have this rgulator ic on my email id.
Thnx
Abhishek
