Введение
Use this guide to remove or replace a broken or worn-out screen assembly including the midframe in the LG G3 (D855).
This guide shows how to replace the whole screen assembly of the LG G3 including the midframe. All components such as the vibration motor, the cameras, and the earpiece speaker need to be transferred to the replacement part during the repair process. In case you want to replace the LCD without the frame you need to follow this guide.
Выберете то, что вам нужно
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
Work your way along the right edge.
Carefully lift the right edge of the motherboard cover.
Remove the motherboard assembly.
Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
Grab the top section of the motherboard and carefully lift it out of the phone.
Insert one of the tweezer arms under the vibration motor and pry it up.
Remove the vibration motor.
Apply a heated iOpener to the bottom end of the screen to loosen the adhesive underneath.
Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers.
Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
If possible turn on your phone and test your replacement part before reassembling your phone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
129 участников успешно повторили данное руководство.
42 Комментариев
Ok so after I did all this my screen is black and so I ordered a second screen and also nothing the phone works great and makes noises also touch responds but nothing on lcd just black can you help me with this also if I take battery out and plug up charger it shows a battery warning on lcd so clearly it works
Has it sustained any water damage?
Did you get it working i have the same issue? the picture displays with the original screen but not with the new one. i have tried 3 different screens and get the same on all of them. i even tried updating to the latest software but only get a black screen, no picture.
When i have had this on iphones i just so a reset by holding down the buttons and the screen starts to work.
Please someone help
Matt -
Same here! I also findout that lcd still works, if you get some flashlight on screen in a dark room, you will see that only backlight not working when battery plugged. I tried to baking it but it still didn't worked. It's obvious that backlight could properly operate as it works when you take off the battery. I'm looking for solutions, if I find any, will wrote it here.
Did someone find a solution to this? I also replaced my screen and it keeps black solid when I turn it on, even with the touch working properly.
