LG G6 USB-C Port Replacement
Архивированное руководство
Это руководство сохранено для исторических целей. Используйте его обновлённую версию, чтобы выполнить ремонт.
Выберете то, что вам нужно
    1. LG G6 USB-C Port Replacement, iOpener Heating: шаг 1, изображение 1 из 2 LG G6 USB-C Port Replacement, iOpener Heating: шаг 1, изображение 2 из 2
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      Спросите у FixBot
      Добавить комментарий
    2. LG G6 USB-C Port Replacement: шаг 2, изображение 1 из 1
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      Спросите у FixBot
    3. LG G6 USB-C Port Replacement: шаг 3, изображение 1 из 1
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      Спросите у FixBot
    4. LG G6 USB-C Port Replacement, Alternate iOpener heating method: шаг 4, изображение 1 из 2 LG G6 USB-C Port Replacement, Alternate iOpener heating method: шаг 4, изображение 2 из 2
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      Спросите у FixBot
    1. LG G6 USB-C Port Replacement, Battery: шаг 5, изображение 1 из 1
      • Apply the heated iOpener to the edge of the phone for about 2 minutes.
      Спросите у FixBot
    2. LG G6 USB-C Port Replacement: шаг 6, изображение 1 из 3 LG G6 USB-C Port Replacement: шаг 6, изображение 2 из 3 LG G6 USB-C Port Replacement: шаг 6, изображение 3 из 3
      Инструмент, используемый на этом этапе:
      Plastic Cards
      $2.99
      • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
      • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
      • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
      Спросите у FixBot
    3. LG G6 USB-C Port Replacement: шаг 7, изображение 1 из 2 LG G6 USB-C Port Replacement: шаг 7, изображение 2 из 2
      • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
      Спросите у FixBot
    4. LG G6 USB-C Port Replacement: шаг 8, изображение 1 из 2 LG G6 USB-C Port Replacement: шаг 8, изображение 2 из 2
      • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
      Спросите у FixBot
    5. LG G6 USB-C Port Replacement: шаг 9, изображение 1 из 1
      • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
      Спросите у FixBot
    6. LG G6 USB-C Port Replacement: шаг 10, изображение 1 из 3 LG G6 USB-C Port Replacement: шаг 10, изображение 2 из 3 LG G6 USB-C Port Replacement: шаг 10, изображение 3 из 3
      • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
      • Do not use a knife as you may pierce the battery.
      Спросите у FixBot
    1. LG G6 USB-C Port Replacement, Motherboard: шаг 11, изображение 1 из 2 LG G6 USB-C Port Replacement, Motherboard: шаг 11, изображение 2 из 2
      • Locate the sim card tray release mechanism on the right edge.
      • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
      Спросите у FixBot
    2. LG G6 USB-C Port Replacement: шаг 12, изображение 1 из 3 LG G6 USB-C Port Replacement: шаг 12, изображение 2 из 3 LG G6 USB-C Port Replacement: шаг 12, изображение 3 из 3
      • Gently pry off the two connectors at the bottom of the phone.
      • Pry off the tape covering the vibrator.
      Спросите у FixBot
    3. LG G6 USB-C Port Replacement: шаг 13, изображение 1 из 2 LG G6 USB-C Port Replacement: шаг 13, изображение 2 из 2
      • The motherboard is now removable by gently lifting.
      • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
      Спросите у FixBot
    1. LG G6 USB-C Port Replacement, USB-C Port: шаг 14, изображение 1 из 2 LG G6 USB-C Port Replacement, USB-C Port: шаг 14, изображение 2 из 2
      • Gently pry the USB-c port assembly out of the frame.
      Спросите у FixBot
Заключение
8 человек успешно провели ремонт по этому руководству.
David Pugliese
Участник с: 09/26/17
1 156 Репутация
Автор 4 руководств
Команда
USF Tampa, Team S2-G6, Passmore Fall 2017 Участник USF Tampa, Team S2-G6, Passmore Fall 2017
USFT-PASSMORE-F17S2G6
4 членов
Автор 36 руководств
2 Комментарии к руководству
what size tape did you use?
Miguel “CharlieMike” Dias - Ответить Поделиться
I skipped removing the main board and was able to remove the port by just lifting the PCB up a little. I also did not remove the battery. just disconnected it. was able the slide out and in the USB port with no trouble or damage.
tenchi50 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 6
За последние 30 дней: 27
За всё время: 10,120
