Введение
Remove the battery before removing the back controls to avoid electric shock. Do not lose any screws or the middle button of the back controls.
Выберете то, что вам нужно
Flip the LG K7 over so that the back of the phone is facing up.
Locate the small notch on the bottom left side of the phone.
Insert a plastic opening tool into the notch and lift the back cover upward while holding the bottom portion of the phone down to remove it.
Located to nine 3.4 mm screws that keep that keep the phones rear housing in tacked.
Using a Phillips 00 screwdriver remove all nine 3.4 mm screws.
Turn the phone over so the screen is facing up
Insert your plastic opening tool between the midframe and front panel assembly on the side of the phone.
Slide the plastic opening tool down the seams carefully to separate the screen from the rest of the phone housing.
Locate the ribbon cable that holds the camera's ribbon cable in place.
Carefully remove the camera's ribbon cable from the motherboard using the plastic removal tool.
Holding the camera ribbon you just released pull upwards and the camera should release from the case.
Еще один человек закончил это руководство.
