LG Optimus F3 Charging port unit Replacement
Выберете то, что вам нужно
    1. LG Optimus F3 Charging port unit  Replacement, Motherboard: шаг 1, изображение 1 из 1
      • Turn the device so that the back faces up.
      • It is easiest to open the case near the charging port located at the bottom of the phone.
      • Remove the back case by pushing up on the back and pulling down on the face as illustrated in the image.
      Спросите у FixBot
      Добавить комментарий
    2. LG Optimus F3 Charging port unit  Replacement: шаг 2, изображение 1 из 1
      • With back case removed, the battery is visible. The battery is the large square object.
      • Remove the battery by flipping the bottom edge upward to separate the battery from the case.
      Спросите у FixBot
    3. LG Optimus F3 Charging port unit  Replacement: шаг 3, изображение 1 из 1
      • Remove 10 1.0 mm screws located on the back of the device.
      • Refer to the outlined locations in the image for the screws.
      Спросите у FixBot
    4. LG Optimus F3 Charging port unit  Replacement: шаг 4, изображение 1 из 1
      • Use the plastic opening tool to separate the inner case from the device.
      • Wedge the plastic opening tool between the case.
      • Wiggle the tool and use leverage to pry the case apart.
      Спросите у FixBot
    5. LG Optimus F3 Charging port unit  Replacement: шаг 5, изображение 1 из 1
      • The camera unit is located at the top left of the phone. The camera is a silver box with a black lens. The image pin points where the camera is on the motherboard.
      • Use the plastic opening tool to separate the camera from the motherboard.
      • Wedge the plastic tool between the camera and the motherboard to loosen the camera unit.
      Спросите у FixBot
    6. LG Optimus F3 Charging port unit  Replacement: шаг 6, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • Use a pair of tweezers to disconnect and remove the rear facing camera.
      Спросите у FixBot
    7. LG Optimus F3 Charging port unit  Replacement: шаг 7, изображение 1 из 1
      • Use the plastic opening tool to separate the sim card and the memory card connector from the motherboard.
      • Note that the sim card and the memory card connector are one unit.
      • Wedge the plastic tool to lift up the sim-memory unit from the motherboard.
      Спросите у FixBot
    8. LG Optimus F3 Charging port unit  Replacement: шаг 8, изображение 1 из 1
      • Use the plastic opening tool to remove the charging port unit.
      • Wedge the plastic opening tool between the charging port unit and the motherboard to separate the port.
      Спросите у FixBot
    9. LG Optimus F3 Charging port unit  Replacement: шаг 9, изображение 1 из 1
      • Use the plastic opening tool to remove the motherboard located directly above the battery encasement.
      • The motherboard is an L-shaped unit above and to the left of the battery encasement.
      • Wedge the plastic opening tool between the circuit board and the motherboard to separate the unit.
      Спросите у FixBot
    1. LG Optimus F3 Charging port unit  Replacement, Charging port unit: шаг 10, изображение 1 из 1
      • Remove one 1.0 mm screw.
      Спросите у FixBot
    2. LG Optimus F3 Charging port unit  Replacement: шаг 11, изображение 1 из 1
      • Use a plastic opening tool to remove front glass protector.
      Спросите у FixBot
    3. LG Optimus F3 Charging port unit  Replacement: шаг 12, изображение 1 из 1
      • Use the plastic opening tool to remove front glass cover carefully. Try not to break the connector.
      Спросите у FixBot
    4. LG Optimus F3 Charging port unit  Replacement: шаг 13, изображение 1 из 1
      • Remove the front facing camera.
      Спросите у FixBot
    5. LG Optimus F3 Charging port unit  Replacement: шаг 14, изображение 1 из 1
      • Use the plastic opening tool to carefully remove the home button board. It is attached with double-sided tape.
      Спросите у FixBot
    6. LG Optimus F3 Charging port unit  Replacement: шаг 15, изображение 1 из 1
      Спросите у FixBot
    7. LG Optimus F3 Charging port unit  Replacement: шаг 16, изображение 1 из 1
      • You are all set.
      Спросите у FixBot
Заключение
3 человек успешно провели ремонт по этому руководству.
Jonathan Fang
Участник с: 10/28/15
356 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 1-5, Miles Fall 2015 Участник UMass Dartmouth, Team 1-5, Miles Fall 2015
UMASSD-MILES-F15S1G5
3 членов
Автор 35 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 0
За последние 7 дней: 30
За последние 30 дней: 50
За всё время: 969
