Введение
This guide will take you through the process of replacing a dead or dying battery in an LG Optimus F60. This task should take no more than 30 seconds to 1 minute. No tools are required for this task but the small blue opening tool is recommended for ease of use.
Выберете то, что вам нужно
Hold the phone in your hand and position the small plastic opening tool or your finger under the lip of the phone by the USB port.
Pry or lift up on the indent with the opening tool.
Remove the back panel.
Place the small plastic opening tool or your finger at the indentation at the base of the battery.
Pry upwards or lift with your finger and remove battery.
Еще один человек закончил это руководство.
