LG Optimus T Button Replacement
Выберете то, что вам нужно
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Using a prying device, such as a Spudger, remove the phone's back cover. At the top of the phone, there's an indentation to put the Spudger into to pop the case off.
      Спросите у FixBot
      Добавить комментарий
    1. LG Optimus T Button Replacement: шаг 2, изображение 1 из 1
      • Remove the battery. There's an indentation to the left of the camera lens to pull up on the battery with your finger.
      Спросите у FixBot
    2. LG Optimus T Button Replacement: шаг 3, изображение 1 из 1
      • Use a J0 screwdriver to remove the six 4.5 mm screws.
      Спросите у FixBot
    3. LG Optimus T Button Replacement: шаг 4, изображение 1 из 2 LG Optimus T Button Replacement: шаг 4, изображение 2 из 2
      • Remove interior case. Insert the spudger into the indentations at the top or bottom of the phone to pry off the interior case.
      • You might have difficulty popping the case off. You may use the metal spudger if the plastic one fails. Be cautious when using it, as the metal spudger may damage your phone.
      Спросите у FixBot
    4. LG Optimus T Button Replacement: шаг 5, изображение 1 из 3 LG Optimus T Button Replacement: шаг 5, изображение 2 из 3 LG Optimus T Button Replacement: шаг 5, изображение 3 из 3
      • Remove power button found on top of the phone.
      • Remove the volume button found on the side of the phone.
      • There is an indentation that has been marked near the edge that part of the volume button inserts in to. You will use this when reassembling your phone.
      • When reassembling your phone, place buttons on the metal nodes that have been marked.
      Спросите у FixBot
    5. LG Optimus T Button Replacement: шаг 6, изображение 1 из 1
      • Pull up on connector tab.
      Спросите у FixBot
    6. LG Optimus T Button Replacement: шаг 7, изображение 1 из 2 LG Optimus T Button Replacement: шаг 7, изображение 2 из 2
      • Remove SD card mount. Insert a plastic opening tool on the right side to pop off.
      Спросите у FixBot
    7. LG Optimus T Button Replacement: шаг 8, изображение 1 из 2 LG Optimus T Button Replacement: шаг 8, изображение 2 из 2
      • There are 4 retaining points to insert a plastic opening tool into and pop off panel.
      Спросите у FixBot
    8. LG Optimus T Button Replacement: шаг 9, изображение 1 из 1
      • Remove 2 black J0 Phillip's head 1.8 mm screws from charging port.
      • Charging port and motherboard are connected.
      • Remove motherboard.
      Спросите у FixBot
    9. LG Optimus T Button Replacement: шаг 10, изображение 1 из 2 LG Optimus T Button Replacement: шаг 10, изображение 2 из 2
      • Pop off home buttons.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Patrick Esguerra
Участник с: 02/07/17
126 Репутация
1 руководство автора
Команда
Ohio State, Team 1-3, Wilder Spring 2017 Участник Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 членов
Автор 35 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 18
За последние 30 дней: 39
За всё время: 464
