Введение
If the phone is having internet issues or memory problems, replacing the SIM/SD Port could resolve these problems.
Выберете то, что вам нужно
Using your thumbnail, lift up on the notch in the middle of the bottom side of the phone.
Using either your thumbnail or a plastic opening tool, lift up on the battery using the notch in the bottom left hand corner of the battery and remove it from the phone.
Use the plastic opening tool to firmly pry up the plastic backing around the perimeter of the phone.
Detach the black rectangular film attached to the SIM/SD card plate with a plastic opening tool.
Gently wiggle the plate side-to-side while pulling up to release it from the metal clamps holding it in.
