Введение
The motherboard is a circuit board that connects and controls the phone's components.
Выберете то, что вам нужно
Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
Use a plastic opening tool to disconnect the touchscreen from the motherboard.
Remove SIM card by sliding it out of its housing.
Remove the front-facing camera using a plastic opening tool.
Remove rear-facing camera using a plastic opening tool.
Connect these three components to the new motherboard.
3 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
ممكن تشريح بوردة lg ls660
For those that find this guide and are looking to dissasemble an lg tribute 2, Make sure to remove your sim card before romoving the cover that has screws. other than that its the same, but i spent a half hour removing my cover carefully just to find out the sd card had held the cover and motherboard togeather, causing Added risk of damage.
