Введение
The rear facing camera on the LG Tribute is a fairly simple component to replace. The phone takes only a couple minutes to break down, and the camera can be replaced without any soldering.
Выберете то, что вам нужно
Remove eight 4mm screws using a Phillips head 000 screwdriver (PH000).
Disconnect the rear facing camera from the motherboard using a plastic opening tool.
Lift the rear facing camera out of its housing.
2 человек успешно провели ремонт по этому руководству.
