LG VX5600 Motherboard Replacement
Выберете то, что вам нужно
    1. LG VX5600 Motherboard Replacement, Battery: шаг 1, изображение 1 из 2 LG VX5600 Motherboard Replacement, Battery: шаг 1, изображение 2 из 2
      • Hold your phone with the back casing facing you and the bottom of the phone towards the sky.
      • Push down on the cover and slide down to remove. You should only have to apply minimal pressure.
      Спросите у FixBot
      Добавить комментарий
    2. LG VX5600 Motherboard Replacement: шаг 2, изображение 1 из 2 LG VX5600 Motherboard Replacement: шаг 2, изображение 2 из 2
      • Insert your finger into the small indentation above the battery.
      • Push down on the battery and pull it away from the phone; it will pop out.
      Спросите у FixBot
    1. LG VX5600 Motherboard Replacement, Motherboard: шаг 3, изображение 1 из 2 LG VX5600 Motherboard Replacement, Motherboard: шаг 3, изображение 2 из 2
      • Grasp the edges of the phone with one hand.
      • Unscrew the six 5.0-mm Phillips #000 screws located around each side of the back panel of the phone.
      • The screws are tight, so you will have to use a little force when unscrewing them.
      Спросите у FixBot
    2. LG VX5600 Motherboard Replacement: шаг 4, изображение 1 из 1
      • Insert the spudger into the tab at the top of the back panel and push to release the panel.
      • The back panel will then lift away from the rest of the phone.
      Спросите у FixBot
    3. LG VX5600 Motherboard Replacement: шаг 5, изображение 1 из 2 LG VX5600 Motherboard Replacement: шаг 5, изображение 2 из 2
      • Flip the phone open with the back side still facing you.
      • Grasping the phone from underneath, use your fingers to push up on the keypad until the motherboard can be easily lifted up from the plastic outer casing of the phone.
      • When you do this the plastic camera button will pop out. It is not directly attached to anything. Make sure to save it for reassembly because it must be placed back on its tab at the side with the camera icon facing right side up to work correctly.
      Спросите у FixBot
    4. LG VX5600 Motherboard Replacement: шаг 6, изображение 1 из 1
      Инструмент, используемый на этом этапе:
      • With a pair of tweezers, pull the gold flex cable up disconnecting the motherboard.
      Спросите у FixBot
    5. LG VX5600 Motherboard Replacement: шаг 7, изображение 1 из 1
      • Use your fingers to lift the motherboard up and away from the phone.
      Спросите у FixBot
Заключение
Jessica Bradley
Участник с: 06/04/13
279 Репутация
Автор 2 руководств
Команда
University of Kentucky Louisville, Team 1-5, Chamberlain Spring 2013 Участник University of Kentucky Louisville, Team 1-5, Chamberlain Spring 2013
LOUISVILLE-CHAMBERLAIN-S13S1G5
2 членов
Автор 54 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 2
За последние 7 дней: 12
За последние 30 дней: 35
За всё время: 1,606
