Выберете то, что вам нужно
Slide the back cover off using the release latch with your fingers to expose the battery.
Lift one side of the battery using a plastic opening tool or your fingers.
Carefully remove the battery and set it aside.
Turn your phone around and open the flip phone. The screen is now facing you.
Locate the two grey rubber plugs on the bottom corners of the screen. These plugs cover up two screws.
Remove the two grey screw-covers.
Use the ejection tab at the top to remove the screen.
There is a gap between the case and the screen near the ear piece.
Insert the plastic opening tool in the gap and pry up the screen.
Unscrew the four corners of the screen using 3.21mm screws to separate the top cover of the phone.
Turn your phone around. The battery side will be facing you.
Insert the plastic opening tool into the groove to remove the top cover of the phone.
Carefully open the cover.
Locate the earpiece, which is the black component at the top with black and red wires.
Remove the component. Using a soldering iron, desolder the top ear piece.
