Введение
If you LG Vu CU920 is damaged, fails to hold a charge or power your device on, the battery may need to be replaced. In this guide, instructions are provided to assist you in safely removing your old battery and installing a new one to restore your phone's performance. Please power off your device before proceeding with replacing your battery.
Remove the back cover by firmly pressing against the indent on the back panel. Slide the cover downward and off the phone.
Remove the battery by placing your fingernail or an opening tool at the bottom edge of the battery and lift it out.
Еще один человек закончил это руководство.
