Введение
Use this guide to replace a broken lamp switch. If you have a lamp that won't turn on, this easy repair may be all it needs to get it back to working order.
Выберете то, что вам нужно
Remove the two screws from the bottom inside the socket. These screws hold the silver threaded socket in place.
Partially peel back the felt or cork from bottom of the lamp to gain access to power cord. Take care to avoid tearing.
Push a few inches of the power cord upwards to gain slack to work with. Some cords may have a knot tied here which will need loosened to push slack upwards.
Pull the socket base/switch assembly out of the base to gain access to the screw terminals on the sides.
Unscrew the terminals on each side to release the wires. The screws may be retained so they may not come all the way out.
Attach the wires to the new switch assembly. It doesn't matter which wire goes to which terminal. For a secure connection, bend a hook into the end of the wire and orient it on the screw so the hook closes when the screw is tightened.
Position the socket/switch assembly on the base and pull the power cord from the bottom to set the socket in place. Reattach the felt or cork on the bottom of the lamp.
Pushing downward to hold the socket in place, screw the black outer socket back in place to secure the switch.
Set the sliver threaded socket into place. Turn the socket to align the two screw holes.
After following these steps to replace a non-working switch, you should again have a functional lamp.
10 человек успешно провели ремонт по этому руководству.
2 Комментарии к руководству
A very nice and clear explanation. Unfortunately the pull chain switch in my lap was riveted to the socket so I had to replace the entire socket. It really was easy though and required less steps than your switch replacement. Here’s a video that shows exactly what I did: https://youtu.be/0fLnUPWzLeI
Thanks!
WOW! I almost threw away my fav Lil lamp - vacuuming I tipped over the lamp and it cracked the threaded plastic part - I followed your instructions and now have a nonflickering - fully functioning lamp! Thanks perfect timing
