LaunchPad CleanUp
    • Locate the Terminal and open
    Спросите у FixBot
    Добавить комментарий
    • Type the following command, this will create a backup folder on your desktop for your launchpad app.
    • mkdir ~/Desktop/DB_Backup
    Спросите у FixBot
    • Type the following command to copy the database. This will place it in the back folder that was created in the second step.
    • cp ~/Library/Application\ Support/Dock/*.db ~/Desktop/DB_Backup/
    Спросите у FixBot
    • Type the next command, this will put the LaunchPad back to its original setup and will take all programs out of folders.
    • sqlite3 ~/Library/Application\ Support/Dock/*.db 'DELETE from apps;' \ ' DELETE from groups WHERE title<>""; DELETE from items WHERE rowid>2;' \ && killall Dock
    • However, it should be noted that the folders will not disappear. To get rid of them, simply load at least one app into Launchpad, then drag the app into & out of the folder. It will 'evaporate' when it's empty.
    • If you want to do a full reset of the LaunchPad, I will create another guide for those steps.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Elle Snickens
Участник с: 03/22/14
157 Репутация
1 руководство автора
3 Комментарии к руководству
this command gives a syntax error in High Sierra.
Wade Smith - Ответить Поделиться
It says “no such table” when I copy the command in terminal, I’m using Mac OS high sierra 10.13.6
Michael Z - Ответить Поделиться
It is a very simple method.<a href="https://technumus.com/how-to-remove-icon...>HOW TO REMOVE ICONS FROM DESKTOP MAC</a>
Johan william - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 6
За последние 7 дней: 14
За последние 30 дней: 65
За всё время: 4,357
