Введение
This guide will show you how to remove your Keyboard in order to replace with a new one of the same model.
Выберете то, что вам нужно
Hold the right battery lock open with one hand while removing the battery itself with the other.
Remove the three 3 mm Phillips screws holding the keyboard in. These screws are designated by an imprinted keyboard picture next to them.
Carefully pry off the keyboard with your plastic opening tool , moving along the edges.
Carefully lift the keyboard.
Turn over the keyboard to locate the keyboards ribbon cable.
Use the plastic opening tool to lift open the ribbon connector that is holding the ribbon cable in its slot.
3 человек успешно провели ремонт по этому руководству.
