Введение
Follow this guide to remove the optical drive from the computer.
Выберете то, что вам нужно
Turn off the computer.
Disconnect the charging cable from the computer.
Flip the computer upside down.
Locate the two switches that lock the battery. Push the right-hand switch outward into the "unlocked" position.
Push and hold the left hand switch outward in the "unlocked" position, then gently slide the battery away from the computer.
Remove the seven 5.3 mm Phillips #1 screws holding the back panel in place.
Pull the back panel off using the highlighted tab. The tab should give you enough leverage to pull the panel off smoothly.
The computer should be open with many of the internal components shown. You can now access the hard drive, the RAM, and the keyboard.
Locate the Optical Drive 4.7 mm Philips #1 screw, which secures the Optical Drive into the body of the laptop.
Using the Philips #1 Screwdriver, remove the Optical Drive 4.7 mm Philips #1 screw. Once you remove the screw, locate the metal tab beneath the screw and push it outwards.
7 человек успешно провели ремонт по этому руководству.
