Введение
This guide will show you how to replace a RAM stick in a Lenovo ThinkPad T470S laptop. RAM replacement may be necessary if there is an error in your RAM or if there is not enough RAM.
Выберете то, что вам нужно
Use a Phillips #000 screwdriver to remove the five 7 mm screws from the bottom of the laptop.
Lift the bottom panel up and off the laptop.
Push out the spring-loaded mechanism that is holding the RAM stick in place.
Slide the RAM stick out.
2 человек успешно провели ремонт по этому руководству.
