Введение
This guide is for removing the ThinkPad X100e's LCD display and replacing it with a new one.
Выберете то, что вам нужно
Инструмент, используемый на этом этапе:Spudger$2.99
Use a Spudger tool to remove the screw covers on each side of the screen.
Using a magnetic screwdriver fit with a PH0 Bit, unscrew the two screws and carefully set the aside.
Remove all exposed screws and carefully set them aside. There should be 6 visible screws.
Lift the screen up carefully, and remove the screws on both sides of the panel. There should be 4 screws.
Fold the panel over until a strip of black tape is visible.
Peel the tape down until you get to the base.
Еще один человек закончил это руководство.
1 Комментарий к руководству
What can be used as a replacement screen, as it's listed not for sale?
