Выберете то, что вам нужно
Step 2. Remove all the screws: Keep all the screws and disconnect the cables carefully.
Step 3. Lift: After removing all the cables, lift up and flip over the PCB.
Step 4. Remove: Remove marked screws on top and around the lent.
**Remove all the parts, be aware that there are a lot of screws and keep count them a long the way of the dissambley **
Step 5. Carefully remove as much of the glue as possible before proceeding to the next step.
Step 6. Remove the marked focus spacers.
Place a bead of silicone adhesive on each side of the ir filter to fix it in position and allow to cure.
