Введение
A failing motor will severely limit your Levoit Core 300-RAC air purifier's performance. If your device is not outputting enough air, or the fan doesn't seem to be spinning, then it may be time to replace the motor. This guide will walk you through the process of replacing the motor of your Levoit Core 300-RAC air purifier.
Before you begin, turn off your air purifier and unplug it from the power outlet.
Выберете то, что вам нужно
Use a Phillips #2 screwdriver to remove the four screws that secure the gray lid towards the base of the device.
Use a metal spudger or Jimmy to gently pry between the four white tabs and the white housing to release the outer housing.
Grab the cable channel by its base, squeeze, and pull up at the same time to remove it.
Insert a Jimmy or spudger between the white tab and the gray faceplate body to release the faceplate.
Lift it out.
Insert the Jimmy between the gray grille cover and the top of the device.
Work your way around the grille cover with the Jimmy to release the clips holding it in place.
Remove the grille cover gently as it is connected by a ribbon cable.
Squeeze the tab on the connector to release the bundled cable from the control board.
Insert a spudger or Jimmy into the four tabs to release them from holding the outer white housing to the inner black core.
Remove the white outer housing.
Use a Phillips #2 screwdriver to remove the three screws holding the top of the black center section to the middle section.
Insert a spudger into the slots around the seam to gently pry the upper part off of the assembly.
Feed the ribbon connector through the space in the top part of the assembly before removing it.
Squeeze down on the clips holding the connectors in place to release the cables.
Use a Phillips #2 screwdriver to remove the three screws located around the fan cover.
Use a 13 mm socket wrench with an extension to remove the nut holding the fan in place. Remove all hardware from the threaded shaft.
Pry apart the motor housing using a spudger inserted into the notches around the seam.
Use a Phillips #2 screwdriver to remove the three flange screws holding the motor in place.
To reassemble your device, follow these instructions in reverse order. You may use solder and heat shrink tubing, or wire nuts to reconnect the power cable.
2 человек успешно провели ремонт по этому руководству.
5 Комментарии к руководству
Thanks for a comprehensive teardown, and here because I'm thinking of making a new control board for the Leovit. One thing, the article seems to fall short on one crucial point though, given that it's about replacing the motor, and that's where to get a replacement and details about the motor itself. Being pedantic, it also doesn't actually describe how to replace the motor, only how to get to the stage of being able to replace it.
Yes, where can we order the new motor?
Hello, thanks for the instructions, do you have a photo of the production label of the fan please? I can't read it. Thank you. John
Thank you for your instructions. Our Levoit 300 is making a high pitched sound. I've read on other sites to grease the bearings. Could you please explain how I can find the bearings and what they look like?
Thank you
I have same question. I have a high-pitched sound coming out of it and have read that I should lubricate the motor. Is there a way to do that without doing this complete teardown? And how and where do I do it?
