Введение
This guide will teach you how to fully deconstruct the mouse and remove the green motherboard.
Выберете то, что вам нужно
Use a Phillips #00 screwdriver to unscrew all 6 screws (3x5mm) from under the mouse feet.
Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the mouse’s internal hardware.
Инструмент, используемый на этом этапе:Tweezers$4.99
Use tweezers to grip and detach the white ribbon cable from the motherboard.
Use a Phillips #00 screwdriver to unscrew all 5 screws (3x5mm ) from the battery pack and motherboard.
10 человек успешно провели ремонт по этому руководству.
5 Комментарии к руководству
So can I buy a new motherboard? Where? I don’t see one available on this site.
Hi there Kat. Did you eventually find out where to get a new motherboard for your G602 mouse?
Jerico, I’ve got a problem with my g602, as the mouse is depleting new batteries energy. I put new batteries on, and they are immediately recognized as “low batteries” by the mouse system, flashing the led indicator as low battery as well. Any thoughts?
I'm having the same problem. Where you able to fix the problem?
Completed successfully.
The hardest part was to find a spare mainboard.
