Введение
This guide shows how to replace the buttons on the Logitech Harmony 900. This is useful for if your buttons get stuck or broken.
Выберете то, что вам нужно
Press the oval shaped button on the lower back of the remote to release the battery cover.
While pressing the button, remove the cover.
Инструмент, используемый на этом этапе:Tweezers$4.99
Using tweezers, peel off the sticker located under the battery cover to reveal two screws.
Locate the three 50mm screws on the back of the remote and remove them using the Phillips #0 screwdriver.
Pry the black, front face of the remote from the back silver part by inserting a credit card in between and sliding down.
When you look at the circuit board, you should see a ribbon attaching the board to the plastic casing.
A little lever is holding the ribbon in place. Lift the lever with your nail or a 2.5mm flat-head screwdriver. Move the ribbon away from the circuit board.
Using the Philips #0 screwdriver, remove the three 50mm screws from the circuit board.
Using your hands, carefully separate the motherboard from the rest of the remote.
Еще один человек закончил это руководство.
